跳转到主内容
Acer Spin 5 SP513-51-57TP Solid State Drive Replacement
你所需要的
  1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 2 中的图像 1,2 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 3 中的图像 1,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 3 中的图像 2,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 4 中的图像 1,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 4 中的图像 2,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 5 中的图像 1,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 5 中的图像 2,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 5 中的图像 3,3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: 步骤 6 中的图像 1,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: 步骤 6 中的图像 2,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: 步骤 6 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
  7. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 7 中的图像 1,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 7 中的图像 2,3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 步骤 7 中的图像 3,3
    • Use your hand to pull out the Solid State Drive from the motherboard.
    • You will be pulling the solid state drive out to the left, as it will be connected to the port on the motherboard on its right side. This is opposite the direction that the pictures depict it.
结论
另外一个人完成了本指南。
Anthony Vansell
于01/24/20注册
872 声望
创作了5篇指南
团队
Hufflepuff Hufflepuff 的会员
Local Repair Groups
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 1,902
