跳转到主内容
Acer Spin 5 SP513-51-57TP Battery Replacement
你所需要的
  1. Acer Spin 5 SP513-51-57TP Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 2 中的图像 1,2 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 3 中的图像 1,3 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 3 中的图像 2,3 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 4 中的图像 1,3 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 4 中的图像 2,3 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 5 中的图像 1,3 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 5 中的图像 2,3 Acer Spin 5 SP513-51-57TP Battery Replacement: 步骤 5 中的图像 3,3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
结论
2等其他人完成本指南。
Anthony Vansell
于01/24/20注册
872 声望
创作了5篇指南
团队
Hufflepuff Hufflepuff 的会员
Repair Café
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 50
总计 3,271
