跳转到主内容
Acer Spin 5 N17W2 SSD Replacement
你所需要的
  1. Acer Spin 5 N17W2 SSD Replacement, Battery: 步骤 1 中的图像 1,2 Acer Spin 5 N17W2 SSD Replacement, Battery: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 SSD Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 SSD Replacement: 步骤 3 中的图像 1,1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 SSD Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 SSD Replacement: 步骤 5 中的图像 1,1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 SSD Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 SSD Replacement, SSD: 步骤 7 中的图像 1,1
    • Disconnect the SSD from the laptop.
    • At the time of guide creation, the device did not come equipped with the SSD.
结论
2条评论
That's not the RAM, that's the m.2 SSD slot. The RAM on this laptop is soldered to the mainboard and cannot be replaced/repaired.
Stephen Feger - 回复
Ok, so they changed this guide from a RAM change to an SSD change. Fine. One thing to point out is that the default m.2 drive for this laptop is a SATA based m.2, not a PCIe. Not sure if it can handle a PCIe m.2 drive.
Stephen Feger -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 1,767
