跳转到主内容
Acer Spin 3 SP315-51-757C Battery Replacement
你所需要的
  1. Acer Spin 3 SP315-51-757C Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Spin 3 SP315-51-757C Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 2 中的图像 1,3 Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 2 中的图像 2,3 Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 2 中的图像 3,3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 3 中的图像 1,1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Battery Replacement, Battery: 步骤 4 中的图像 1,2 Acer Spin 3 SP315-51-757C Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 5 中的图像 1,3 Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 5 中的图像 2,3 Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Battery Replacement: 步骤 6 中的图像 1,1
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
结论
3等其他人完成本指南。
3条评论
Wasted $50 on a battery that doesn’t work. I’m still trying to find why my Acer 2 in 1 will no longer turn on.
E L - 回复
That is a bummer, and something that concerns me as well. I’d like to replace the battery but it’s so common to get a failed battery or one that fails in a short period of time. Recently I’ve purchased two consecutive bad lithium drill batteries from ebay. Hope you get your computer figured out.
Adam Kahler -
I believe this guide would apply to most or all of the SP315-51-XXX laptops. I have a -79NT and the process and internals look the same.
Adam Kahler - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 31
总计 3,799
