本指南有最近更改,您可查看未经巡查的最新版本。
简介
Using the Acer S200HL LCD Monitor motherboard replacement and removal guide, this process will become easier using these simple iFixit steps.
你所需要的
Place the monitor screen face down.
Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
Pull the stand away from the monitor.
Use the plastic opening tool to pry the back panel from the front panel.
Start at one point of the crease and pry along the edge of the entire monitor for the best results.
Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
The following steps circled in yellow are the locations for detaching the three connectors shown in the picture.
Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
Lift the black seal to release the large ribbon connector (the ZIF connector).
Pull the bundled cable connector gently away from motherboard.
7等其他人完成本指南。
