跳转到主内容
Acer Predator Helios PH315-51 RAM Replacement
你所需要的
  1. Acer Predator Helios PH315-51 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • There are two panels on the back. The smallest is the RAM panel.
  2. Acer Predator Helios PH315-51 RAM Replacement: 步骤 2 中的图像 1,1
    • Remove the single screw holding the panel using a Phillips #1 screwdriver.
    • Use your fingernail to remove the panel.
  3. Acer Predator Helios PH315-51 RAM Replacement: 步骤 3 中的图像 1,1
    • Push the clip down and move it left.
    • Push the clip down and move it right.
  4. Acer Predator Helios PH315-51 RAM Replacement: 步骤 4 中的图像 1,2 Acer Predator Helios PH315-51 RAM Replacement: 步骤 4 中的图像 2,2
    • The RAM should pop up when clips are moved.
    • Remove the RAM.
    • The RAM should easily be removed from the pins making sure no damage is done to the pins.
  5. Acer Predator Helios PH315-51 RAM Replacement: 步骤 5 中的图像 1,1
    • Before inserting the new RAM, make sure there are more pins on the left side of the new RAM before the space in between so that the RAM goes in the slot correctly.
    • When the RAM is inserted, push it down and the hinges will automatically hold the RAM in its place.
    • Make sure to not apply pressure to any part. Everything should be done with care and ease.
  6. Acer Predator Helios PH315-51 RAM Replacement: 步骤 6 中的图像 1,1
    • Close the panel by using the Phillips #1 screwdriver.
结论
To make sure everything works correctly, power ON the laptop. It will take longer than usual to boot up because the RAM is initializing itself. When the laptop turns ON, go to about Your PC section and there you will see installed RAM and now your laptop is ready to use.
Aakarshak Jain
于07/26/23注册
233 声望
撰写一个指南
团队
York University, Team M-5, Allen Summer 2023 York University, Team M-5, Allen Summer 2023 的会员
YORK-ALLEN-SU23SMG5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 269
