简介
If your Acer Predator 17 G9-793 boots when plugged in but does not retain a charge or remain on when unplugged, it might have a defective battery, or the battery has gone through too many charging cycles and is at the end of its lifespan.
The battery stores power for the computer so it may be used away from a constant power source. If you aren't able to use your Acer Predator 17 G9-793 laptop anymore unless it's plugged into the charger, follow this guide to replace the battery.
Before you begin, power off the device completely and unplug it from the charger.
你所需要的
Use a Phillips #0 screwdriver to unscrew the two captive screws on the service panel cover.
Use a spudger or opening tool to remove the service panel.
另外一个人完成了本指南。
