跳转到主内容
Acer Predator 17 G9-791 Service Panel Replacement
你所需要的
  1. Acer Predator 17 G9-791 Service Panel Replacement, Service Panel: 步骤 1 中的图像 1,1
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Service Panel Replacement: 步骤 2 中的图像 1,2 Acer Predator 17 G9-791 Service Panel Replacement: 步骤 2 中的图像 2,2
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Service Panel Replacement: 步骤 3 中的图像 1,1
    • Continue pulling up on the panel to separate it from the laptop and remove it.
结论
Matthew Shane
于10/25/22注册
376 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S5G1
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 133
