跳转到主内容
Acer Predator 17 G9-791 Display Replacement
你所需要的
  1. Acer Predator 17 G9-791 Display Replacement, Service Panel: 步骤 1 中的图像 1,1
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Display Replacement: 步骤 2 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 2 中的图像 2,2
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Display Replacement: 步骤 3 中的图像 1,1
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Display Replacement, Bottom Case: 步骤 4 中的图像 1,3 Acer Predator 17 G9-791 Display Replacement, Bottom Case: 步骤 4 中的图像 2,3 Acer Predator 17 G9-791 Display Replacement, Bottom Case: 步骤 4 中的图像 3,3
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Display Replacement: 步骤 5 中的图像 1,1
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Display Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Display Replacement: 步骤 7 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 7 中的图像 2,2
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Display Replacement, Battery: 步骤 8 中的图像 1,1
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Display Replacement: 步骤 9 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 9 中的图像 2,2
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Display Replacement: 步骤 10 中的图像 1,1
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Display Replacement, Fan Assembly: 步骤 11 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement, Fan Assembly: 步骤 11 中的图像 2,2
    • Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
  12. Acer Predator 17 G9-791 Display Replacement: 步骤 12 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 12 中的图像 2,2
    • Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
  13. Acer Predator 17 G9-791 Display Replacement: 步骤 13 中的图像 1,3 Acer Predator 17 G9-791 Display Replacement: 步骤 13 中的图像 2,3 Acer Predator 17 G9-791 Display Replacement: 步骤 13 中的图像 3,3
    • Detach the left fan's cord from the motherboard.
  14. Acer Predator 17 G9-791 Display Replacement: 步骤 14 中的图像 1,3 Acer Predator 17 G9-791 Display Replacement: 步骤 14 中的图像 2,3 Acer Predator 17 G9-791 Display Replacement: 步骤 14 中的图像 3,3
    • Detach the right fan's cord from the motherboard.
  15. Acer Predator 17 G9-791 Display Replacement: 步骤 15 中的图像 1,3 Acer Predator 17 G9-791 Display Replacement: 步骤 15 中的图像 2,3 Acer Predator 17 G9-791 Display Replacement: 步骤 15 中的图像 3,3
    • Lift the fan assembly up and out.
  16. Acer Predator 17 G9-791 Display Replacement, Display: 步骤 16 中的图像 1,3 Acer Predator 17 G9-791 Display Replacement, Display: 步骤 16 中的图像 2,3 Acer Predator 17 G9-791 Display Replacement, Display: 步骤 16 中的图像 3,3
    • Push down on the back of the device to unclip this panel, removing it by pulling it out the back of the device.
  17. Acer Predator 17 G9-791 Display Replacement: 步骤 17 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 17 中的图像 2,2
    • Remove two black 7 mm Phillips #0 screws from the left display bracket.
    • Remove the two silver 5 mm Phillips #0 screws from the left display bracket.
  18. Acer Predator 17 G9-791 Display Replacement: 步骤 18 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 18 中的图像 2,2
    • Remove three silver 5 mm Phillips #0 screws from the right display bracket.
    • Remove one black 7 mm Phillips #0 screw from the right display bracket.
  19. Acer Predator 17 G9-791 Display Replacement: 步骤 19 中的图像 1,3 Acer Predator 17 G9-791 Display Replacement: 步骤 19 中的图像 2,3 Acer Predator 17 G9-791 Display Replacement: 步骤 19 中的图像 3,3
    • Remove one 4.5 mm Phillips #0 screw from the WLAN card.
    • Pull the WLAN card out.
  20. Acer Predator 17 G9-791 Display Replacement: 步骤 20 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 20 中的图像 2,2
    • Turn the device around.
    • Pull the black tab to disconnect one wire from the bottom of the motherboard.
  21. Acer Predator 17 G9-791 Display Replacement: 步骤 21 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 21 中的图像 2,2
    • Opening the cover slightly, pull the bottom half of the device towards you.
  22. Acer Predator 17 G9-791 Display Replacement: 步骤 22 中的图像 1,2 Acer Predator 17 G9-791 Display Replacement: 步骤 22 中的图像 2,2
    • Separate the wire that was unplugged two steps ago from the bottom of the device.
    • This wire runs in a track and pulling on it slightly will separate it from the bottom half of the device.
    • When reinstalling, ensure this wire in placed back in its track before attempting to put the new display on the device.
结论
Adeline Slocum
于10/25/22注册
304 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S5G1
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 357
