跳转到主内容
Acer One 10 S1003-19GY WiFi Antenna Replacement
你所需要的
  1. Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY WiFi Antenna Replacement: 步骤 2 中的图像 1,1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: 步骤 3 中的图像 1,3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: 步骤 3 中的图像 2,3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: 步骤 3 中的图像 3,3
    • Disconnect the black ribbon connection attached to the motherboard.
    • Remove the chip fully by pulling the plastic tab on the left out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 681
