跳转到主内容
Acer One 10 S1003-19GY Rear/Front Camera Replacement
你所需要的
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 2 中的图像 1,1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: 步骤 3 中的图像 1,1
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 4 中的图像 1,3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 4 中的图像 2,3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 4 中的图像 3,3
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 6 中的图像 1,2 Acer One 10 S1003-19GY Rear/Front Camera Replacement: 步骤 6 中的图像 2,2
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 353
