跳转到主内容
Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair
你所需要的
  1. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: 步骤 1 中的图像 1,2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: 步骤 1 中的图像 2,2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: 步骤 2 中的图像 1,1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: 步骤 3 中的图像 1,3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: 步骤 3 中的图像 2,3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: 步骤 3 中的图像 3,3
    • Flip the latch and carefully pull the ribbon free.
  4. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: 步骤 4 中的图像 1,2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: 步骤 4 中的图像 2,2
    • Remove the two screws holding the dock in place using a Phillips #0 screwdriver.
    • Pull the dock out and slide it out of the device.
结论
一条评论
dove acquistare questo connettore :Acer ONE 10 (S1003 D16H1) Docking Port Connector Cable, grazie . francescomar25@gmail.com
Francesco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,248
