跳转到主内容
Acer One 10 S1003-114M Track Pad Replacement
你所需要的
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: 步骤 1 中的图像 1,1
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: 步骤 2 中的图像 1,1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: 步骤 3 中的图像 1,2 Acer One 10 S1003-114M Track Pad Replacement: 步骤 3 中的图像 2,2
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: 步骤 4 中的图像 1,3 Acer One 10 S1003-114M Track Pad Replacement: 步骤 4 中的图像 2,3 Acer One 10 S1003-114M Track Pad Replacement: 步骤 4 中的图像 3,3
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: 步骤 6 中的图像 1,1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: 步骤 7 中的图像 1,1
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: 步骤 8 中的图像 1,2 Acer One 10 S1003-114M Track Pad Replacement: 步骤 8 中的图像 2,2
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: 步骤 9 中的图像 1,2 Acer One 10 S1003-114M Track Pad Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: 步骤 10 中的图像 1,3 Acer One 10 S1003-114M Track Pad Replacement: 步骤 10 中的图像 2,3 Acer One 10 S1003-114M Track Pad Replacement: 步骤 10 中的图像 3,3
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: 步骤 11 中的图像 1,1
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: 步骤 12 中的图像 1,1
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: 步骤 13 中的图像 1,1
    • Gently remove the trackpad from the keyboard.
结论
Karan Karthik
于04/01/19注册
217 声望
撰写一个指南
团队
IUPUI, Team S2-G6, Harley Spring 2019 IUPUI, Team S2-G6, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S2G6
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 759
