简介
Is your camera broken, preventing it from taking quality photos? If so, here is a guide to fix the problem. Be cautious when removing and handling the fragile camera.
你所需要的
Make sure the device is turned off and disconnected from any power source.
To disconnect the tablet from the keyboard attachment, open the laptop and lift the tablet component up from the keyboard dock.
Starting from the corner of the tablet, use a jimmy to create a gap between the screen and the back covering.
Insert a metal spudger in the gap that you created with the Jimmy.
Slowly maneuver the metal spudger along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Using a spudger, disconnect the two ribbon cables on the top right and the three on the bottom left of the motherboard.
在这个步骤中使用的工具:Tweezers$4.99
Use tweezers to grab the camera's edges and gently lift the camera up from tablet backing.
Remove the camera from the device.
