简介
Is your motherboard dead, preventing your device from functioning? If so, here is a guide to remove your motherboard.
你所需要的
Make sure the device is turned off and disconnected from any power source.
To disconnect the tablet from the keyboard attachment, open the laptop and lift the tablet component up from the keyboard dock.
Starting from the corner of the tablet, use a jimmy to create a gap between the screen and the back covering.
Insert a metal spudger in the gap that you created with the Jimmy.
Slowly maneuver the metal spudger along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Using a spudger, disconnect the two ribbon cables on the top right and the three on the bottom left of the motherboard.
2等其他人完成本指南。
