简介
If your tablet seriously malfunctions, (e.g. it is not turning on), a replacement motherboard may be needed. Motherboards in tablets are much smaller than traditional motherboards, and this guide shows you how to properly replace yours.
你所需要的
Make sure that the tablet is turned off and disconnected from any power source.
Disconnect the tablet from the keyboard attachment.
If you have a Micro SD card in the tablet, remove it now.
Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
12等其他人完成本指南。
11条评论
WOW. Thank you so much for this guide. My keyboard wasn't connecting and last time I had to send it to Acer ...and that took a month. This time it is out of warranty and it wouldn't connect again!!!.... After opening it following this guide, it was immediately visible that the cable was out.
Thank you SO much!
Alen Mijic - 回复
put it aside and then?
Hey,
Whenever you see a 'put aside' anywhere in a guide there's an implied 'then continue' afterwards.
Hope that helps!
Great help. Was able to restore connection for my grandson’s computer using your clear concise directions. THANK YOU!!!
how can i fix my acer one s1002 keyboard dock it is not working if i connect it to the tablet i
