跳转到主内容
Acer One 10 S1002 145-A Battery Replacement
你所需要的
  1. Acer One 10 S1002 145-A Battery Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
    I don't find the screws
    Andrea Spedaletti - 回复
  2. Acer One 10 S1002 145-A Battery Replacement: 步骤 2 中的图像 1,2 Acer One 10 S1002 145-A Battery Replacement: 步骤 2 中的图像 2,2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
    Doing this, i’ve broke some of the “hook” thing that keepsthe plastic back plate to the screen, so now is loose and not well closed. How can I solve it?
    Lorenzo Giraudi - 回复
    I need motherboard for Acer one 10 s1001
    Abdul Majeed Hajam - 回复
  3. Acer One 10 S1002 145-A Battery Replacement: 步骤 3 中的图像 1,3 Acer One 10 S1002 145-A Battery Replacement: 步骤 3 中的图像 2,3 Acer One 10 S1002 145-A Battery Replacement: 步骤 3 中的图像 3,3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Battery Replacement: 步骤 4 中的图像 1,2 Acer One 10 S1002 145-A Battery Replacement: 步骤 4 中的图像 2,2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Battery Replacement: 步骤 5 中的图像 1,3 Acer One 10 S1002 145-A Battery Replacement: 步骤 5 中的图像 2,3 Acer One 10 S1002 145-A Battery Replacement: 步骤 5 中的图像 3,3
  6. Acer One 10 S1002 145-A Battery Replacement: 步骤 6 中的图像 1,2 Acer One 10 S1002 145-A Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Battery Replacement: 步骤 7 中的图像 1,3 Acer One 10 S1002 145-A Battery Replacement: 步骤 7 中的图像 2,3 Acer One 10 S1002 145-A Battery Replacement: 步骤 7 中的图像 3,3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Battery Replacement: 步骤 8 中的图像 1,1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Battery Replacement, Battery: 步骤 9 中的图像 1,3 Acer One 10 S1002 145-A Battery Replacement, Battery: 步骤 9 中的图像 2,3 Acer One 10 S1002 145-A Battery Replacement, Battery: 步骤 9 中的图像 3,3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
结论
20等其他人完成本指南。
Shannon Griffin
于10/03/16注册
1,372 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Sullivan Fall 2016 USF Tampa, Team 1-3, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S1G3
4 名成员
创作了5篇指南
2条评论
Thankyou for this information. I am replacing a battery on my own, and your tutorial is extremely clear and helpful.
shop_arod - 回复
I want a ..
Motherboard
4D Guru Channel - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 65
总计 18,676
