跳转到主内容
Acer Nitro 5 AN515-55-55M1 Motherboard Replacement
你所需要的
  1. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 2 中的图像 1,2 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: 步骤 3 中的图像 1,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: 步骤 3 中的图像 2,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: 步骤 3 中的图像 3,3
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 4 中的图像 1,2 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
  5. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Disconnect the seven cables from the motherboard using an iFixit opening tool.
  6. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 6 中的图像 1,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 6 中的图像 2,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
  7. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 7 中的图像 1,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 7 中的图像 2,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
    • Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
    • Lift the taped wires off of the fans on the right and left sides.
  8. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 8 中的图像 1,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 8 中的图像 2,3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Lift up the right side of the motherboard.
    • The cables may need some guidance to leave the management holes on the motherboard.
    • Continue to lift at an angle until there is a give.
    • Remove the motherboard and fans from the laptop.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 1-4, Mellen Spring 2022 UMass Dartmouth, Team 1-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S1G4
3 名成员
创作了5篇指南
一条评论
Where would I go to buy a new motherboard and display?
David Nguyen - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 31
过去 30 天: 129
总计 5,400
