简介
The fans inside the Acer Nitro 5 AN515-55-53AG laptop can occasionally get stuck, dusty, or fail completely. Fans are essential to the operation of a graphics card (GPU) or central processor (CPU). They help keep the graphics card operating at a low temperature. The GPU will quickly overheat and shut down if the fans are removed or malfunction. Fixing this is often a matter of some small handiwork to get inside the computer and check the fans for what might be sticking. Use this guide to access the internal GPU/CPU cooling fan. From here, it is possible to unjam, clean, or replace the fan as needed.
你所需要的
在这个步骤中使用的工具:Plastic Cards$2.99
Remove the laptop's bottom cover using an opening tool or plastic card.
2等其他人完成本指南。
1指南评论
на an515-55-534c система охлаждения так же разбирается ? или это он и есть ?
