跳转到主内容
Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement
你所需要的
  1. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 1,2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 2,2
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying it up with a plastic opening tool.
  3. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Remove the screw on the Hard Drive tray with a Phillips #0 screwdriver.
    • Lift up the tray covering using a plastic opening tool.
  4. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the fourteen 9mm screws holding the back cover in place.
    • Remove the hard drive (if applicable) from the slot prior to removing the back cover.
    • This device didn't have a hard drive so your device may look different.
  5. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 5 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 5 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Lift the back cover off once all the clips have been disengaged.
  7. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 7 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 7 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 7 中的图像 3,3
    • Using your fingers, disconnect the white and black cables connected to the left side of the Wi-fi card.
  8. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 8 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 8 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 8 中的图像 3,3
    • Remove the screw holding down the Wi-Fi card with a Phillips #0 screwdriver.
  9. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 9 中的图像 1,2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 步骤 9 中的图像 2,2
    • Slide the Wi-Fi card out from its port.
结论
另外一个人完成了本指南。
一条评论
My hard drive got disconnected and I can't locate where is the place to connect it
manueltopete59 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 184
总计 4,188
