跳转到主内容
Acer Nitro 5 AN515-53-55G9 Battery Replacement
你所需要的
  1. Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 2 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 2 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 3 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 3 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 3 中的图像 3,3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 5 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 5 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 5 中的图像 3,3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 6 中的图像 1,2 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 6 中的图像 2,2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
    One part you missed was to tell everyone that the HDD would still be attached to the back shell. I removed the shell and promptly ripped out my HDD cable. Now having to order a new cable…
    Mike Nitchie - 回复
  7. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 7 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 7 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 7 中的图像 3,3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove battery from device.
结论
11等其他人完成本指南。
3条评论
For future articles, you might consider adding a section describing how to “initialize” the replacement battery pack to maximize life.
Either that, or at least mention initialization plays a part in maximizing battery life and point to another article that provides reliable information.
Thanks for the article.
jmagecko - 回复
And how do you put it back in? Cause it’s a pain in the ass to put back in easy to take out pain in the &&^&^$^ ass to put back in
Mally02 - 回复
After I put the new battery the battery indicator doesn't stop flashing orange? any ideas?
Dido - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 48
过去 30 天: 333
总计 37,987
