跳转到主内容
Acer Nitro 5 AN515-53-55G9 Battery Replacement
你所需要的
  1. Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 2 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 2 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 3 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 3 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 3 中的图像 3,3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 5 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 5 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 5 中的图像 3,3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 6 中的图像 1,2 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 6 中的图像 2,2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 7 中的图像 1,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 7 中的图像 2,3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 7 中的图像 3,3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove battery from device.
结论
10等其他人完成本指南。
2条评论
For future articles, you might consider adding a section describing how to “initialize” the replacement battery pack to maximize life.
Either that, or at least mention initialization plays a part in maximizing battery life and point to another article that provides reliable information.
Thanks for the article.
jmagecko - 回复
And how do you put it back in? Cause it’s a pain in the ass to put back in easy to take out pain in the &&^&^$^ ass to put back in
Mally02 - 回复
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 120
过去 30 天: 475
总计 32,959
