跳转到主内容
Acer Nitro 5 AN515-53-52FA Battery Replacement
你所需要的
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 2 中的图像 1,2 Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 3 中的图像 1,2 Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 3 中的图像 2,2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 5 中的图像 1,2 Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 6 中的图像 1,2 Acer Nitro 5 AN515-53-52FA Battery Replacement: 步骤 6 中的图像 2,2
    • Lift the battery up and out of the laptop.
结论
另外一个人完成了本指南。
Alfredo Prieto
于09/01/22注册
827 声望
创作了5篇指南
团队
Gateway, Team 1-3, Pee Fall 2022 Gateway, Team 1-3, Pee Fall 2022 的会员
GCC-PEE-F22S1G3
4 名成员
创作了5篇指南
2条评论
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - 回复
Can I use a Jimmy instead of the opening picks?
SomeDude372 - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 80
总计 950
