跳转到主内容
Acer Nitro 5 AN515-44-R70B Fan Replacement
你所需要的
  1. Acer Nitro 5 AN515-44-R70B Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before beginning the fan replacement
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the eleven M2.5x6.0 size screws holding the back cover in place.
  3. Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 3 中的图像 1,2 Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the back shell from the device.
    • Do not be too forceful as you could damage the shell.
  4. Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 4 中的图像 1,1
    • For extra caution slide out the battery cable from its connector using your fingers.
  5. Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, slide out the two fan cables from their connectors.
  6. Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 6 中的图像 1,2 Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the gaffer tape next to the fan.
  7. Acer Nitro 5 AN515-44-R70B Fan Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the four M2.5x6.0 size screws holding the fan assembly in place.
    • You can now remove the old fans and replace them with new ones.
结论
Ilyass Sellouf
于01/15/24注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 65
总计 222
