跳转到主内容
Acer Iconia W3-810 Speaker Replacement
你所需要的
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: 步骤 4 中的图像 1,1
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: 步骤 5 中的图像 1,1
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: 步骤 7 中的图像 1,1
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: 步骤 8 中的图像 1,1
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: 步骤 10 中的图像 1,1
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: 步骤 11 中的图像 1,1
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: 步骤 12 中的图像 1,1
    • Remove the speakers from the device.
结论
Griffin Hocker
于09/15/16注册
394 声望
创作了3篇指南
团队
USF Tampa, Team 18-4, Blackwell Fall 2016 USF Tampa, Team 18-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 404
