跳转到主内容
Acer Iconia W3-810 Rear-Facing Camera Replacement
你所需要的
  1. Acer Iconia W3-810 Rear-Facing Camera Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Rear-Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 3 中的图像 1,1
    • Lift the retaining flap fastening the ribbon cord to the motherboard using a plastic opening tool.
  4. Acer Iconia W3-810 Rear-Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon cord from its slot using a plastic opening tool.
  5. Acer Iconia W3-810 Rear-Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the rear-facing camera from its slot and pose for a camera shot.
结论
Adam Fierce
于09/15/16注册
418 声望
创作了3篇指南
团队
USF Tampa, Team 18-4, Blackwell Fall 2016 USF Tampa, Team 18-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 428
