跳转到主内容
Acer Iconia W3-810 Battery Replacement
你所需要的
  1. Acer Iconia W3-810 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
  4. Acer Iconia W3-810 Battery Replacement: 步骤 4 中的图像 1,1
    • Move the ribbon cord in order to disconnect the rainbow cord from the battery.
    • Take extra care to not rip the ribbon cord.
  5. Acer Iconia W3-810 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to carefully slide the power cord from its slot by pushing it out from both sides, then remove the cord from its port with your hand.
  6. Acer Iconia W3-810 Battery Replacement: 步骤 6 中的图像 1,1
    • Pull on the ribbon cord carefully in order to break the seal between the ribbon cord and the battery. Do this until the cord is completely free of the battery.
    • Do not pull the ribbon cord too hard or near the opposite end.
  7. Acer Iconia W3-810 Battery Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to gently wedge out and lift the battery pack from the device.
  8. Acer Iconia W3-810 Battery Replacement: 步骤 8 中的图像 1,2 Acer Iconia W3-810 Battery Replacement: 步骤 8 中的图像 2,2
    • Carefully break the bond between the inner tape and the battery using the plastic opening tool. The tape can be found in the middle and either side of the battery.
  9. Acer Iconia W3-810 Battery Replacement: 步骤 9 中的图像 1,1
    • Remove battery pack
结论
3等其他人完成本指南。
Adam Fierce
于09/15/16注册
418 声望
创作了3篇指南
团队
USF Tampa, Team 18-4, Blackwell Fall 2016 USF Tampa, Team 18-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G4
4 名成员
创作了6篇指南
一条评论
Good show .i like the simple steps
alibar1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 16
总计 4,106
