简介
This guide will give you a step by step process for replacing the screen of an Acer Iconia W3-810 in the case of a screen failure. This guide can be used if the screen is cracked due to physical damage or burns out from excessive use.
你所需要的
Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
Disconnect the speaker cord from the motherboard by carefully prying it out with a plastic opening tool.
3等其他人完成本指南。
