简介
One of the most common repairs on modern devices is the screen. The screen usually cracks due to physical damage. This guide will demonstrate screen replacement for the Acer Iconia Tab A501.
你所需要的
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
Use the Halberd Spudger to carefully pop up and take out the ports.
Use the Jimmy to carefully remove the front camera from the front cover of the tablet.
