简介
The motherboard directly connects almost all of a device’s parts. If your motherboard is having problems or has failed, you may decide to replace it. This guide will demonstrate replacing a motherboard for the Acer Iconia Tab A501.
你所需要的
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
即将完成!
结论
