跳转到主内容
你所需要的
  1. Acer Iconia Tab A500 USB Port Replacement, Back Case: 步骤 1 中的图像 1,1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 USB Port Replacement: 步骤 2 中的图像 1,1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 USB Port Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Acer Iconia Tab A500 USB Port Replacement: 步骤 4 中的图像 1,1
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  5. Acer Iconia Tab A500 USB Port Replacement, USB Port: 步骤 5 中的图像 1,1
    • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
  6. Acer Iconia Tab A500 USB Port Replacement: 步骤 6 中的图像 1,1
    • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
  7. Acer Iconia Tab A500 USB Port Replacement: 步骤 7 中的图像 1,1
    • Disconnect the blue cable by gently lifting the flap.
    • Remove the indicated 2mm screw holding the speaker in place.
  8. Acer Iconia Tab A500 USB Port Replacement: 步骤 8 中的图像 1,1
    • Pull up the metal panel just enough to allow access, then remove the USB port.
结论
4等其他人完成本指南。
Sam Macy
于2014年04月01日注册
1,161 声望
撰写一个指南
团队
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G23
4 名成员
创作了19篇指南
2条评论
Awesome I love the visual of the steps. Thank you!
_Samsunz
samiam6 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 3,407
