当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
To start, gently separate one corner of the case using the black spudger.
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Locate the 4 screws and cable that hold in the two speakers.
Use the Phillips #1 screwdriver to remove these 2mm black screws.
Remove the 2mm silver screws.
Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
Carefully remove the connector cable by pushing on the rim of black plastic insert.
Unfortunately, the top speaker is a wedged under the motherboard.
To get this speaker out, use the spudger and gently pry it out.
取消:我没有完成这个指南。
2等其他人完成本指南。
与5其他贡献者
于04/07/14注册
1,006 声望
创作了7篇指南
徽章: 15
+ 12更多徽章
CPSU-REGAN-S14S7G23
4 名成员
创作了19篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 8
总计 1,989
