当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Locate the 4 screws and cable that hold in the two speakers.
Use the Phillips #1 screwdriver to remove these 2mm black screws.
Remove the 2mm silver screws.
Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
Unfortunately, the top speaker is a wedged under the motherboard.
To get this speaker out, use the spudger and gently pry it out.
Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
They may be different sizes, the silver are 5mm and the black are 2mm.
Disconnect the two gold connectors by pulling straight up on them with your fingers.
Like before, lift up on the black flap to detach the cable.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
