跳转到主内容
Acer Iconia Tab A500 Power Button/Motherboard Replacement
你所需要的
  1. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Back Case: 步骤 1 中的图像 1,1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 2 中的图像 1,1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Speakers: 步骤 3 中的图像 1,1
    • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
    • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
  4. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 4 中的图像 1,2 Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  5. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unfortunately, the top speaker is a wedged under the motherboard.
    • To get this speaker out, use the spudger and gently pry it out.
  6. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  7. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  8. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Power Button: 步骤 8 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
    • They may be different sizes, the silver are 5mm and the black are 2mm.
    I need a on off switch
    shutt2010 - 回复
  9. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift up on the black flaps to release the flat cables.
    • Pull this Connector off.
  10. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use the spudger to detach the indicated cables.
    • Remove the last motherboard screw under the rightmost cable. It is a silver 5mm.
  11. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 11 中的图像 1,1
    • Disconnect the two gold connectors by pulling straight up on them with your fingers.
    • Like before, lift up on the black flap to detach the cable.
  12. Acer Iconia Tab A500 Power Button/Motherboard Replacement: 步骤 12 中的图像 1,1
    • Having disconnected all those pesky cables, the motherboard lifts cleanly out.
    price for motherboard
    greenhulk5219 - 回复
结论
From here, you can solder on a new switch or put in the new motherboard. To reassemble your device, follow these instructions in reverse order.
20等其他人完成本指南。
Kyle Libby
于04/07/14注册
1,006 声望
创作了7篇指南
团队
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G23
4 名成员
创作了19篇指南
2条评论
where can I get the switch?
Dan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 14,554
