跳转到主内容
Acer Iconia Tab A200 Microphone Replacement
你所需要的
  1. Acer Iconia Tab A200 Microphone Replacement, Battery: 步骤 1 中的图像 1,2 Acer Iconia Tab A200 Microphone Replacement, Battery: 步骤 1 中的图像 2,2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Microphone Replacement: 步骤 2 中的图像 1,2 Acer Iconia Tab A200 Microphone Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Microphone Replacement: 步骤 3 中的图像 1,2 Acer Iconia Tab A200 Microphone Replacement: 步骤 3 中的图像 2,2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Microphone Replacement: 步骤 4 中的图像 1,2 Acer Iconia Tab A200 Microphone Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Microphone Replacement: 步骤 5 中的图像 1,2 Acer Iconia Tab A200 Microphone Replacement: 步骤 5 中的图像 2,2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
  6. Acer Iconia Tab A200 Microphone Replacement, Microphone: 步骤 6 中的图像 1,2 Acer Iconia Tab A200 Microphone Replacement, Microphone: 步骤 6 中的图像 2,2
    • Lift up on the microphone cable to lift the microphone component away from the case.
  7. Acer Iconia Tab A200 Microphone Replacement: 步骤 7 中的图像 1,1
    • Once the microphone has been lifted away from the case, disconnect the microphone cable from the motherboard by pulling the cable out horizontally. Do not lift up to remove.
结论
Jaimie Payne
于03/06/16注册
477 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 156
