跳转到主内容
Acer Iconia Tab A200 DC Power Jack Component Replacement
你所需要的
  1. Acer Iconia Tab A200 DC Power Jack Component Replacement, Battery: 步骤 1 中的图像 1,2 Acer Iconia Tab A200 DC Power Jack Component Replacement, Battery: 步骤 1 中的图像 2,2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 2 中的图像 1,2 Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 3 中的图像 1,2 Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 3 中的图像 2,2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 4 中的图像 1,2 Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 5 中的图像 1,2 Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 5 中的图像 2,2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
  6. Acer Iconia Tab A200 DC Power Jack Component Replacement, DC Power Jack Component: 步骤 6 中的图像 1,1
    • Using the plastic opening tool gently lift up the charging component out of its slot in the case.
  7. Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 7 中的图像 1,1
    • Continue to lift up the cord until it is free from the case and only attached to the motherboard.
    • You may need to continue using the plastic opening tool to lift the cord out of the case due to limited hand space.
  8. Acer Iconia Tab A200 DC Power Jack Component Replacement: 步骤 8 中的图像 1,1
    • Disconnect the power component from the motherboard by pulling it out horizontally. Do not pull up on the cord only pull out
结论
3等其他人完成本指南。
Jaimie Payne
于03/06/16注册
477 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G5
3 名成员
创作了6篇指南
2条评论
Probably no need to REPLACE the jack. Just push the little indented tabs in a fraction of a millimeter and it will make good contact again. I just did this with mine and it works perfectly now after having been a royal PITA for over a year.
hammondkeys - 回复
Will this work if I bought a charger that either charges inside the tip connected to the prong, or thru the outer side of the plug. I used the wrong setting and now I only see the green robot on his side. It won't boot
karen p - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,385
