简介
Most components either connect or interface with the motherboard in some way. Because there is a lot involved, this guide shows how to remove it properly.
你所需要的
Insert the plastic opening tool into the seam between the back case and the display.
Work the plastic opening tool around the seam until the rear case separates from the display.
Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
Using the spudger, remove the two tabs shown by placing the spudger under the gray part of the connectors and pulling on the tabs.
3等其他人完成本指南。
