跳转到主内容
Acer Iconia Tab 8 A1-840 Battery Replacement
你所需要的
  1. Acer Iconia Tab 8 A1-840 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
  5. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the flat end of the spudger to pry up and remove the battery cable.
  6. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the flat side of the heavy duty spudger to lift the small black plastic flap.
  7. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 7 中的图像 1,1
    • Use fingers to pull the Zero Insertion Force (ZIF) cable from the motherboard.
  8. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 8 中的图像 1,1
    • Use fingers to remove the smaller adjacent ZIF cable from the motherboard.
  9. Acer Iconia Tab 8 A1-840 Battery Replacement: 步骤 9 中的图像 1,1
    • Use the flat end of the spudger to pry the battery up from all edges, and remove it from the back panel.
    • There is adhesive behind the battery that holds it in place. Be sure to pry slowly and carefully when removing the battery.
结论
6等其他人完成本指南。
Claire Posadas
于10/18/16注册
396 声望
创作了3篇指南
团队
UW Tacoma, Team 1-1, Rose Fall 2016 UW Tacoma, Team 1-1, Rose Fall 2016 的会员
UWT-ROSE-F16S1G1
4 名成员
创作了6篇指南
3条评论
It looks like not too hard to fix it
Guerry's Som - 回复
Hello, what are white and yellow cables, could I somehow replace original battery with generic (2 wire lipo - cheaper one) . can those 2 wires be cut and could tablet work? thanks
Milan Lazić - 回复
Hello , can I replace this 4 wire battery with 2 wire generic one ? What are white and yellow cables , could they be removed or somehow reconnected for use of 2 wire (red and black) generic tablet battery. Thanks
Milan Lazić - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 5,343
