跳转到主内容
Acer Iconia One 8 Battery Replacement
你所需要的
  1. Acer Iconia One 8 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Acer Iconia One 8 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: 步骤 3 中的图像 1,1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 2,843
