跳转到主内容
Acer Iconia One 7 Speaker Replacement
你所需要的
  1. Acer Iconia One 7 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult; use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Speaker Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Speaker Replacement: 步骤 3 中的图像 1,1
    • Turn the tablet over to locate the speaker.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
    • The speaker is on the bottom of the inside.
  4. Acer Iconia One 7 Speaker Replacement: 步骤 4 中的图像 1,2 Acer Iconia One 7 Speaker Replacement: 步骤 4 中的图像 2,2
    • Peel back tape.
    • Using tweezers, detach connection from motherboard.
  5. Acer Iconia One 7 Speaker Replacement: 步骤 5 中的图像 1,3 Acer Iconia One 7 Speaker Replacement: 步骤 5 中的图像 2,3 Acer Iconia One 7 Speaker Replacement: 步骤 5 中的图像 3,3
    • Unscrew screws with a JIS screwdriver with a #00 screw bit.
    • Dislodge the speaker unit.
    • Take care not to displace any other bits in the device.
结论
Michael
于09/03/15注册
519 声望
创作了4篇指南
团队
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 396
