跳转到主内容
简介
The rear facing camera is utilized when taking pictures in front of the device. In this case it is separated from the front facing camera and works separately as well. Pieces regarding this camera are significantly small so be aware of any missing items.
配件
没有特定配件。
  1. Begin at any side of the tablet.
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Using a plastic opening tool, separate the back cover from the main device.
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Turn the tablet over to locate the camera on the top left.
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Peel black tape. Detach clip from motherboard.
    • Peel black tape.
    • Detach clip from motherboard.
  5. Take out film object using tweezers. Using tweezers take out camera.
    • Take out film object using tweezers.
    • Using tweezers take out camera.
结论
Michael
于2015年09月03日注册
516 信誉积分
创作了4篇指南
团队
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G5
3 名成员
创作了5篇指南
一条评论
How to get new camera if the original camera is damaged
Prakash Hasabnis - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 349
