当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Reminder: Turn off device before you start opening your tablet.
Begin at any side of the tablet.
With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
Use caution when prying the lid open to avoid damaging your tablet.
Using a plastic opening tool, separate the back cover from the main device
Open each side continuously to ensure all sides have been separated,
Turn tablet over.
Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
Carefully peel back the copper foil to reveal the motherboard.
Peel tape back to expose connections.
There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
Gently pull out motherboard.
取消:我没有完成这个指南。
4等其他人完成本指南。
与6其他贡献者
于09/03/15注册
519 声望
创作了4篇指南
徽章: 9
+ 6更多徽章
USFT-EYESTONE-F15S8G5
3 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,532
