跳转到主内容
简介
Tablet motherboard's can wear out and sometimes they need to be replaced. This guide walks you through the necessary steps to replace it effectively. The motherboard embedded into this device requires specific tools and techniques to remove and replace it.
    • Reminder: Turn off device before you start opening your tablet.
  1. Begin at any side of the tablet.
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Using a plastic opening tool, separate the back cover from the main device
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Turn tablet over.
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Carefully peel back the copper foil to reveal the motherboard.
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Peel tape back to expose connections.
    • Peel tape back to expose connections.
  6. There are several sets of wires connected to the motherboard as shown in the images.  Carefully disconnect each set of wires. There are several sets of wires connected to the motherboard as shown in the images.  Carefully disconnect each set of wires.
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw. Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Gently pull out motherboard.
    • Gently pull out motherboard.
结论
3等其他人完成本指南。
Michael
于2015年09月03日注册
516 信誉积分
创作了4篇指南
团队
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 2,315
