跳转到主内容
Acer Iconia One 7 Motherboard Replacement
你所需要的
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: 步骤 7 中的图像 1,2 Acer Iconia One 7 Motherboard Replacement: 步骤 7 中的图像 2,2
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: 步骤 8 中的图像 1,2 Acer Iconia One 7 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Gently pull out motherboard.
结论
4等其他人完成本指南。
Michael
于09/03/15注册
519 声望
创作了4篇指南
团队
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 2,535
