跳转到主内容
加入维修社区 - 创建账户
Acer Iconia One 7 Battery Replacement
你所需要的
    1. Acer Iconia One 7 Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
      询问修复机器人
      添加评论
    2. Acer Iconia One 7 Battery Replacement: 步骤 2 中的图像 1,1
      • Using a plastic opening tool, separate the back cover from the main device.
      • Open each side continuously to ensure all sides have been separated.
      询问修复机器人
      添加评论
    3. Acer Iconia One 7 Battery Replacement: 步骤 3 中的图像 1,1
      • Turn the tablet over so the battery is facing up.
      询问修复机器人
      添加评论
    4. Acer Iconia One 7 Battery Replacement: 步骤 4 中的图像 1,2 Acer Iconia One 7 Battery Replacement: 步骤 4 中的图像 2,2
      • Carefully pull back the black tape covering the battery lead connector.
      • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
      询问修复机器人
      添加评论
    5. Acer Iconia One 7 Battery Replacement: 步骤 5 中的图像 1,3 Acer Iconia One 7 Battery Replacement: 步骤 5 中的图像 2,3 Acer Iconia One 7 Battery Replacement: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Using a plastic card or opening pick, separate the battery from the rest of the device.
      • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
团队
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G5
3 名成员
创作了5篇指南
4指南评论
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - 回复 分享
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - 回复 分享
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - 回复 分享
Where I can order the new battery part?
melanieloa3 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 53
总计 19,145
