跳转到主内容
Acer Iconia One 10 B3-A30 Repair Motherboard Replacement
你所需要的
  1. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 2 中的图像 1,3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 2 中的图像 2,3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 4 中的图像 1,2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 4 中的图像 2,2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 5 中的图像 1,3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 5 中的图像 2,3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 5 中的图像 3,3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 7 中的图像 1,2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 7 中的图像 2,2
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 8 中的图像 1,1
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 9 中的图像 1,2 Acer Iconia One 10 B3-A30 Repair Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using the small plastic tool, carefully pry the motherboard out of the device.
结论
2等其他人完成本指南。
Austin Pickart
于09/28/17注册
688 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 的会员
USFT-NANCE-F17S1G5
4 名成员
创作了5篇指南
一条评论
The button flex cable retaining clip is broken, do you have this available?
Craig Olmscheid - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 16
总计 3,802
