跳转到主内容
Acer Iconia One 10 B3-A30 Repair Battery Replacement
你所需要的
  1. Acer Iconia One 10 B3-A30 Repair Battery Replacement, Battery: 步骤 1 中的图像 1,2 Acer Iconia One 10 B3-A30 Repair Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 2 中的图像 1,3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 2 中的图像 2,3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 2 中的图像 3,3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 3 中的图像 1,1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 4 中的图像 1,2 Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 4 中的图像 2,2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 5 中的图像 1,3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 5 中的图像 2,3 Acer Iconia One 10 B3-A30 Repair Battery Replacement: 步骤 5 中的图像 3,3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
结论
8等其他人完成本指南。
Austin Pickart
于09/28/17注册
688 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Nance Fall 2017 USF Tampa, Team S1-G5, Nance Fall 2017 的会员
USFT-NANCE-F17S1G5
4 名成员
创作了5篇指南
6条评论
after replacing battery it will not turn on. There is a red light on when I plug in to charge. But screen is black. Nothing lights up not even a battery icon to show charging. Could the hard drive have been wiped in changing battery? Or that I waited too long to change battery as I used the tablet plugged in to the point the thing kept turning off even when plugged in
I have ACER iconia 10” tablet model B3-A40
howru100 - 回复
My problem ws iconia one a3_a40 is after start it says os android starting.and then message Power off turning down. Take time to start again.first touch lead to turning off message.is it android or acer bag?
alex_kolenko - 回复
First contac .taap on screen turns. Off device. service center technitian. Told me never to use android. Tauchscreen.
alex_kolenko - 回复
Means to use android without. Tapping screen keyboard or better to ask teenager in secondary school.they know better than educated ingeneeres. I am thinking to buy new gadget.
alex_kolenko - 回复
I have one of these and the battery is not taped down which is causing it to disconnect at times. Can anyone recommend a heat resistant tape to hold the battery in place?
Mark Cooper - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 63
总计 13,834
