当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Because I can't switch-off the tablet, I'm using the reset button to do this.
With a cutter and a plastic tool remove the back cover.
If you have a memory card inside, don't forget to remove it!
First, disconnect the battery.
Now, disconnect the loudspeaker and remove the back cover.
Remove all scotch tapes and disconnect the touch screen flex cable...
LCD display flex cable,
the microphone,
and the WiFi and Bluetooth antennas flex cables.
The battery is glued to the LCD display metal shield with a double sided adhesive tape.
Use plastic tools and carefully remove it.
Remove all tapes from the LCD display metal shield.
The LCD display is held by metal frame and some locking clips on it.
Use a cutter and a plastic tool to separate the LCD.
You have to work slowly so as not to break the display.
Now, install the new LCD display and reassemble the tablet.
Warm up the touch screen.
Start separating from one of the corners. With a cutter, make place for a plastic tool.
Keep warm the touchscreen to separate it easily.
For us is important to keep only the frame.
Before installing the new touch screen, clean the frame and put double side adhesive tape.
For the cleaning you can use an alcohol.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
