跳转到主内容
Acer Iconia B1-720 Motherboard Replacement
你所需要的
  1. Acer Iconia B1-720 Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Motherboard Replacement: 步骤 2 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 2 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Motherboard Replacement: 步骤 3 中的图像 1,2 Acer Iconia B1-720 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Acer Iconia B1-720 Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Motherboard Replacement: 步骤 6 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 6 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
  7. Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: 步骤 7 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: 步骤 7 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: 步骤 7 中的图像 3,3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  8. Acer Iconia B1-720 Motherboard Replacement: 步骤 8 中的图像 1,2 Acer Iconia B1-720 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  9. Acer Iconia B1-720 Motherboard Replacement: 步骤 9 中的图像 1,2 Acer Iconia B1-720 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  10. Acer Iconia B1-720 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Remove the yellow tape covering both ribbons in the two photos shown.
  11. Acer Iconia B1-720 Motherboard Replacement: 步骤 11 中的图像 1,2 Acer Iconia B1-720 Motherboard Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  12. Acer Iconia B1-720 Motherboard Replacement: 步骤 12 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 12 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  13. Acer Iconia B1-720 Motherboard Replacement: 步骤 13 中的图像 1,2 Acer Iconia B1-720 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use tweezers to gently remove black ribbon from locking mechanism.
  14. Acer Iconia B1-720 Motherboard Replacement: 步骤 14 中的图像 1,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 14 中的图像 2,3 Acer Iconia B1-720 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
结论
另外一个人完成了本指南。
Kervis Boston
于03/18/15注册
479 声望
创作了3篇指南
团队
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,414
