跳转到主内容
Acer Iconia B1-720 Microphone/Speaker Replacement
你所需要的
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: 步骤 1 中的图像 1,3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: 步骤 1 中的图像 2,3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 2 中的图像 1,3 Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 2 中的图像 2,3 Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 2 中的图像 3,3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 3 中的图像 1,2 Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 3 中的图像 2,2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: 步骤 4 中的图像 1,3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: 步骤 4 中的图像 2,3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: 步骤 4 中的图像 3,3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 5 中的图像 1,2 Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 5 中的图像 2,2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 6 中的图像 1,2 Acer Iconia B1-720 Microphone/Speaker Replacement: 步骤 6 中的图像 2,2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
结论
Phillip Keavey
于03/17/15注册
319 声望
创作了2篇指南
团队
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 688
